Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Replacing the cabinet air filter is recommended every 25,000 miles. It can be done by following some easy steps
  1. This fix is for 2010 Audi A4
    • This fix is for 2010 Audi A4
  2. Locate the cabinet air filter under the passenger's glove box. Locate the cabinet air filter under the passenger's glove box.
    • Locate the cabinet air filter under the passenger's glove box.
  3. Locate the two screws on the panel. By hand, turn the screws to remove them. By hand, turn the screws to remove them.
    • Locate the two screws on the panel.
    • By hand, turn the screws to remove them.
  4. Push the white cover to the direction of the arrow to remove it. You should see the filter after you remove the white cover. You should see the filter after you remove the white cover.
    • Push the white cover to the direction of the arrow to remove it.
    • You should see the filter after you remove the white cover.
  5. Pull the filter down to remove it. Make sure to remember the direction of the removed filter.
    • Pull the filter down to remove it.
    • Make sure to remember the direction of the removed filter.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 51
