Saltar al contenido principal
2010-2014 Ford Mustang Coolant Reservoir Replacement
Qué necesitas
  1. 2010-2014 Ford Mustang Coolant Reservoir  Replacement, Coolant Reservoir: paso 1, imagen 1 de 1
    • Make sure the car engine is completely cool before beginning the replacement process. There is a substantial risk to burn yourself if the engine has not had ample time to cool. Allow at least a 2 hour gap between the last time the car was running and the beginning of the work.
    • The radiator and cooling system must be properly drained before this procedure. That process will not be shown in this guide.
    • Disconnect the negative cable from the car battery to eliminate the risk of being shocked while working. Allow car to sit for 5 minutes to make sure leftover power is discharged completely.
  2. 2010-2014 Ford Mustang Coolant Reservoir  Replacement: paso 2, imagen 1 de 1
    • Using an adjustable wrench or 12mm combination wrench, remove the bolts that keep the reservoir attached to engine.
    • If the bolts are rusted or stuck, spray WD-40 or any other penetrant on the bolts and allow it to sit for 5 minutes before attempting to remove the bolts. Make sure to not let oil or any substance drip into the engine bay and wipe clean with a rag when finished.
  3. 2010-2014 Ford Mustang Coolant Reservoir  Replacement: paso 3, imagen 1 de 1
    • Using pliers, an adjustable wrench, or by hand, carefully remove the hose clamps that connect the coolant hoses to the reservoir and allow residual coolant to drain into a drip pan or other sealable container.
    • Wear gloves. Do not allow coolant to enter the area of the face. If coolant spills on the skin, wash the area with soap and water. If coolant enters the eyes, flush with water and receive medical attention.
  4. 2010-2014 Ford Mustang Coolant Reservoir  Replacement: paso 4, imagen 1 de 1
    • Allow excess coolant to drain from the radiator, hoses, and old reservoir to drain into a drip pan or other sealable container.
    • Once the old reservoir is completely drained, pour the waste into a container with a top and dispose of it safely. Coolant should not be poured down drains or onto the ground because it is highly toxic.
    • Attach and clamp coolant hoses to new reservoir. Make sure they are secured tightly and that no gaps are visible.
    • Align reservoir into the correct position and reattach the bolts to the reservoir. Make sure it is held down tightly.
  5. 2010-2014 Ford Mustang Coolant Reservoir  Replacement: paso 6, imagen 1 de 1
    • Fill the new reservoir with coolant to maximum level indicated by the markings on the side of the plastic.
    • It is worth the time to research coolant brands and determine what your car needs before purchasing the product.
  6. 2010-2014 Ford Mustang Coolant Reservoir  Replacement: paso 7, imagen 1 de 1
    • Reattach the negative cable to the battery and ensure the connection is secure. Check to see if the battery provides power by turning the headlights on.
    • Start the car and let it run for 10 minutes. Check for leaks.
    • If the car is overheating, allow it to completely cool and check for coolant leaks. Do not open the coolant cap or attempt to add more coolant while the car is hot.
    • If the car continues to overheat and there are no visible leaks, contact a mechanic.
Conclusión
In case something breaks or an issue with the car arises, do not drive and contact a mechanic.
Una persona más ha completado esta guía.
Alexandra Guerrier
Miembro Desde 01/21/20
199 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 41
Todo El Tiempo: 1,597
