Saltar al contenido principal
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: paso 1, imagen 1 de 1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 2, imagen 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 2, imagen 2 de 2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 3, imagen 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 3, imagen 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 3, imagen 3 de 3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 4, imagen 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 4, imagen 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 4, imagen 3 de 3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 5, imagen 1 de 1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 6, imagen 1 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 6, imagen 2 de 3 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 6, imagen 3 de 3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 7, imagen 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 7, imagen 2 de 2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 8, imagen 1 de 2 2010-2014 BMW X6 Tail Light Bulb Replacement: paso 8, imagen 2 de 2
    • Close trunk and admire your hard work!
Conclusión
Una persona más ha completado esta guía.
Juan M Perez
Miembro Desde 10/05/21
190 Reputación
1 Guía escrita
Equipo
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 75
Todo El Tiempo: 2,192
