Saltar al contenido principal
2010-2015 Hyundai Elantra Spark Plug Replacement
Qué necesitas
  1. 2010-2015 Hyundai Elantra Spark Plug Replacement, Spark Plug Replacement: paso 1, imagen 1 de 1
    • Make sure the car is off and cooled down entirely by allowing at least the car not to be in use for two hours or more.
  2. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 2, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 2, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 2, imagen 3 de 3
    • Open the hood by pulling upwards on the lever found by the lower left side of the driver seat.
    • Lift the hood with your hands by opening the latch that holds the hood down.
    • Prop up the hood stick to hold the hood open.
  3. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 3, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 3, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 3, imagen 3 de 3
    • Loosen and remove the nut next to the battery terminal using the 10mm socket attached to the wrench.
  4. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 4, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 4, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 4, imagen 3 de 3
    • Move the power supply cable aside carefully and wedge it between the battery.
  5. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 5, imagen 1 de 2 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 5, imagen 2 de 2
    • Remove the engine cover by placing both hands on each side and placing it aside from our work station.
  6. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 6, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 6, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 6, imagen 3 de 3
    • Unfasten the lock pins from the electrical connectors and place them aside by the battery.
  7. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 7, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 7, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 7, imagen 3 de 3
    • Unscrew the four screws from the ignition coils using an 8mm socket attached to a wrench.
  8. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 8, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 8, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 8, imagen 3 de 3
    • Remove all four ignition coils and keep them in order as you remove them outside of our work station.
  9. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 9, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 9, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 9, imagen 3 de 3
    • Loosen and remove spark plugs with a ⅝ long socket with an eight-inch socket extension and wrench.
    • Use a magnetic pickup tool to remove the spark plugs.
  10. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 10, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 10, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 10, imagen 3 de 3
    • Insert the new spark plugs gently to avoid damaging the spark plug using the magnetic pickup tool.
  11. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 11, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 11, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 11, imagen 3 de 3
    • Use the 5/8 socket with an 8-inch extension attached to a wrench to tighten the spark plug, without breaking the spark plug.
  12. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 12, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 12, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 12, imagen 3 de 3
    • Insert ignition coils into their designated places.
  13. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 13, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 13, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 13, imagen 3 de 3
    • Insert and tighten screws for the ignition coils using the 10 mm socket attached to the wrench.
  14. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 14, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 14, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 14, imagen 3 de 3
    • Connect all four electrical connectors and lock them back into place.
  15. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 15, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 15, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 15, imagen 3 de 3
    • Place the engine cover back into its designated spot.
  16. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 16, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 16, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 16, imagen 3 de 3
    • Reconnect the battery by moving the power supply cable back into its terminal.
    • Tighten the nut back alongside the terminal using the 10mm socket attached to a wrench.
    • Close the positive terminal battery cover and ensure it is properly closed.
  17. 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 17, imagen 1 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 17, imagen 2 de 3 2010-2015 Hyundai Elantra Spark Plug Replacement: paso 17, imagen 3 de 3
    • Place the hood stick back into its designated spot and gently close the hood.
Linea de Meta
Una persona más ha completado esta guía.
Robert
Miembro Desde 10/25/23
265 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 2-1, Briggs Fall 2023 Miembro de CSU Los Angeles, Team 2-1, Briggs Fall 2023
CSULA-BRIGGS-F23S2G1
6 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 80
Ultimos 30 días: 330
Todo El Tiempo: 1,208
