Saltar al contenido principal
2009 Volkswagen Jetta Key Fob Battery Replacement
Qué necesitas
  1. 2009 Volkswagen Jetta Key Fob Battery Replacement, Battery: paso 1, imagen 1 de 3 2009 Volkswagen Jetta Key Fob Battery Replacement, Battery: paso 1, imagen 2 de 3 2009 Volkswagen Jetta Key Fob Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Insert a 4 cm, flat-head screwdriver into the notch where the key separates into two parts.
    • Twist the screwdriver, slowly and carefully separate the two parts of the key.
  2. 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 3, imagen 1 de 3 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 3, imagen 2 de 3 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 3, imagen 3 de 3
    • At the bottom half of the key with the control panel, place your thumb and index finger in between the side opposite the alarm.
    • Apply force to separate the halves, noting too much force will cause the old battery to move or fall out. If it does not fall out, use the screwdriver to remove the old battery.
  3. 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 4, imagen 1 de 1
    • Get the replacement battery, a new CR2032 3 Volt battery.
  4. 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 5, imagen 1 de 2 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 5, imagen 2 de 2
    • Place the battery positive side (+) down, opposite the green circuit board.
    • Ensure the positive (+) side of the battery is facing downward for proper installation. The battery should have no writing visible when placed correctly.
  5. 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 6, imagen 1 de 2 2009 Volkswagen Jetta Key Fob Battery Replacement: paso 6, imagen 2 de 2
    • Reassemble the key in reverse order.
Conclusión
To reassemble the key fob, proceed to follow these instructions in reverse order.
4 personas más completaron esta guía.
Un comentario
gracias muy buen tutorial
Oscar Xavier Vasquez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 37
Ultimos 30 días: 143
Todo El Tiempo: 5,244
