Saltar al contenido principal
2009 Subaru Impreza WRX Stereo Replacement
Qué necesitas
  1. 2009 Subaru Impreza WRX Stereo Replacement, Stereo: paso 1, imagen 1 de 1
    • Insert a plastic trim removal tool or pry tool into the seam behind the trim surround, and twist lightly.
    • If you don't have a trim removal tool, you can use a thin flathead screwdriver—but be careful not to damage the trim or dash materials.
    • Use your hands to slowly pry off the rest of the trim surround.
  2. 2009 Subaru Impreza WRX Stereo Replacement: paso 2, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 2, imagen 2 de 2
    • Remove the four 8x3/4" Phillips screws highlighted. Then slowly slide the stereo out from its housing.
  3. 2009 Subaru Impreza WRX Stereo Replacement: paso 3, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 3, imagen 2 de 2
    • Unplug both the white and black wiring harnesses by pressing the small tab above the socket connector.
    • Remove the antennae cord by sliding it from its housing.
  4. 2009 Subaru Impreza WRX Stereo Replacement: paso 4, imagen 1 de 3 2009 Subaru Impreza WRX Stereo Replacement: paso 4, imagen 2 de 3 2009 Subaru Impreza WRX Stereo Replacement: paso 4, imagen 3 de 3
    • Locate your aftermarket wiring harness included with the aftermarket stereo.
    • Strip each wire necessary for installation (See Table in Step 7).
  5. 2009 Subaru Impreza WRX Stereo Replacement: paso 5, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 5, imagen 2 de 2
    • Locate the white wiring harness behind the stereo housing.
    • Cut the cords to separate the wires connecting the harness to the car's electrical system.
    • Note: Be careful not to cut the black wiring harness instead. The black harness is for the CD changer and isn't used in this installation.
  6. 2009 Subaru Impreza WRX Stereo Replacement: paso 6, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 6, imagen 2 de 2
    • Strip each wire in the wiring harness necessary for installation.
    • Be careful while stripping the wires. They are extremely brittle and tend to rip easily.
    • Once both the OEM white wiring harness and the black aftermarket wiring harness are stripped, bring the two ends together to start comparing which wires need to be connected.
  7. 2009 Subaru Impreza WRX Stereo Replacement: paso 7, imagen 1 de 1
    • Connect the wires from the two wiring harnesses.
    • Crimp Caps, soldering, or wire butt connectors can be used for the connection. Please see related guides for instruction on each method.
    • Use the table to the left to match up correct wires. Wires not listed are not used in the installation and should either be uncut or taped with electrical tape at the ends.
  8. 2009 Subaru Impreza WRX Stereo Replacement: paso 8, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 8, imagen 2 de 2
    • Once the two wiring harnesses are connected completely, it's time to install the new stereo.
    • Locate the aftermarket installation bracket included with the stereo.
    • Screw it into place with the same four 8x3/4" Phillips screws from the original stereo.
  9. 2009 Subaru Impreza WRX Stereo Replacement: paso 9, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 9, imagen 2 de 2
    • Locate the aftermarket metal spacer.
    • Slide it into the mounting bracket.
    • Press the triangle tabs along each edge to form a solid connection.
    • Note: There may be a slight amount of movement after the tabs are already pressed. Is is unavoidable and most movement will be removed once the stereo is in place.
  10. 2009 Subaru Impreza WRX Stereo Replacement: paso 10, imagen 1 de 1
    • Reconnect the black wiring harness into the new stereo. Be careful of the rejoined wire connections because they are often fragile.
    • Reconnect the antennae cord into the cylindrical slot. If it doesn't fit, you will need to purchase and antennae adapter specific to your car.
  11. 2009 Subaru Impreza WRX Stereo Replacement: paso 11, imagen 1 de 2 2009 Subaru Impreza WRX Stereo Replacement: paso 11, imagen 2 de 2
    • Once the cords are reconnected, slide the stereo back into the housing. It will click into place.
    • Note: Do not force the stereo into place. If it doesn't slid in smoothly, most likely the wiring is in the way and should be adjusted to prevent damage.
    • Snap the final molding back into place to complete the dash.
  12. 2009 Subaru Impreza WRX Stereo Replacement: paso 12, imagen 1 de 1
    • You now have completed the aftermarket stereo installation.
    • Check to see if the stereo has power and connects to the speakers. If there is an electrical issue, follow the troubleshooting tips associated with this guide for more instruction.
Conclusión
5 personas más completaron esta guía.
Matthew Veith
Miembro Desde 04/29/15
263 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-3, Regan Spring 2015 Miembro de Cal Poly, Team 8-3, Regan Spring 2015
CPSU-REGAN-S15S8G3
5 Miembros
5 Guías creadas
Un comentario
OMG! Instead of cutting off the factory power/speaker harness plug, it's much better to obtain an aftermarket wiring harness. You'll be able to combine that to your new stereo's harness on your workbench or kitchen table instead of working in the cramped space in the car's dash, not to mention being able to quickly and easily reinstall the factory stereo if necessary (e.g., when you want to sell the car). For 2008-2014 (and some 2015) Impreza, WRX, STi, Forester, and Crosstrek models that had the non-navigation OEM stereo, you'll want a Metra 70-7552 or Scosche NN04B. Or if your steering wheel has audio controls that you would like to retain, search for similar aftermarket installation harnesses that include the additional SWC wires.
David C - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 111
Todo El Tiempo: 17,573
