Saltar al contenido principal
2009 Subaru Impreza WRX Rear Door Panel Replacement
Qué necesitas
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: paso 1, imagen 1 de 1
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 2, imagen 1 de 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 3, imagen 1 de 1
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 4, imagen 1 de 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 5, imagen 1 de 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 5, imagen 2 de 2
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 6, imagen 1 de 2 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 6, imagen 2 de 2
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 7, imagen 1 de 1
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 8, imagen 1 de 1
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 9, imagen 1 de 1
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 10, imagen 1 de 1
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: paso 11, imagen 1 de 1
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
Conclusión
Joseph Coplon
Miembro Desde 04/20/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-3, Regan Spring 2015 Miembro de Cal Poly, Team 8-3, Regan Spring 2015
CPSU-REGAN-S15S8G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 2,454
