Saltar al contenido principal
2009-2013 Mazda 3 Cabin Air Filter Replacement
Qué necesitas
  1. 2009-2013 Mazda 3 Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 1 de 1
    • Correctly identify and purchase the cabin air filter for your 2009-2013 Mazda 3 model.
    • If needed, visit your local car parts shop for help buying the cabin air filter.
  2. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 2, imagen 1 de 3 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 2, imagen 2 de 3 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 2, imagen 3 de 3
    • Remove the panel under the middle console by pulling from the bottom and then from the top.
    • It is on the passenger side of your vehicle.
  3. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 3, imagen 1 de 2 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 3, imagen 2 de 2
    • Remove the black panel under the passenger-side dashboard by unclipping the two tabs,
    • Unclip by pushing on the tabs.
  4. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 4, imagen 1 de 3 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 4, imagen 2 de 3 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 4, imagen 3 de 3
    • Remove the two 2 mm Phillips screws securing the bottom of the filter housing.
    • Pull the tab at the top of the housing cover to remove it.
    • Handle filter housing parts gently.
  5. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 5, imagen 1 de 1
    • Pull out one of the two air filters.
    • The second filter, located on top of first filter, should fall into the same place as you remove the first one.
    • If the second filter doesn't fall, reach it and gently remove it.
  6. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 6, imagen 1 de 2 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 6, imagen 2 de 2
    • Insert the new filters into the slots.
    • The wide side of the air filter goes last.
    • Position the first filter on top.
    • The first filter should fit and stay on top. It might take a few tries.
    • Ensure the second air filter fits tightly underneath the one on top.
  7. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 7, imagen 1 de 1
    • Place the housing cover back in position.
    • Tighten the two screws to secure the cover.
  8. 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 8, imagen 1 de 2 2009-2013 Mazda 3 Cabin Air Filter Replacement: paso 8, imagen 2 de 2
    • Position the black panel under the passenger side dashboard.
    • Clip the two tabs back into place by pushing on them to secure the panel.
    • Align the side panel back under the middle console.
    • Secure the panel by pushing it back into place from the top and the bottom.
Linea de Meta
Una persona más ha completado esta guía.
Ovi Ahmed
Miembro Desde 10/24/23
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 113
Ultimos 30 días: 584
Todo El Tiempo: 2,110
