Saltar al contenido principal
2009-2015 Toyota Prius Cabin Air Filter Replacement
Qué necesitas
  1. 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 1 de 2 2009-2015 Toyota Prius Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 2 de 2
    • Press the button to open the glove box.
  2. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 2, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 2, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 2, imagen 3 de 3
    • Pull hook away from glove box that's located on the right side, near the passenger door.
  3. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 3, imagen 1 de 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 3, imagen 2 de 2
    • On the opposite side of the glove box, apply pressure and pull it towards you to unlatch the left side.
  4. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 4, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 4, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 4, imagen 3 de 3
    • Hold both sides of the glove box.
    • Push the sides in and lift the glove box up while pulling towards you, to remove the glove box from its compartment.
  5. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 5, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 5, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 5, imagen 3 de 3
    • Push in the tab on the right side of the filter cover while pulling it towards you.
  6. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 6, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 6, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 6, imagen 3 de 3
    • Remove the old air filter by lifting it up slightly and pulling it towards you.
  7. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 7, imagen 1 de 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 7, imagen 2 de 2
    • Insert the new cabin air filter by aligning it with the empty space and sliding in.
    • Make sure the arrow on the cabin air filter is pointing in the up direction.
  8. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 8, imagen 1 de 2 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 8, imagen 2 de 2
    • Insert the left side of the cover back into its slot.
    • Push the right side of the cover back into its clip to secure it.
  9. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 9, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 9, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 9, imagen 3 de 3
    • Align the hooks on the glove box with the square holes located at the bottom of the dash.
    • Push the glove box back into the compartment until the sides click into place.
  10. 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 10, imagen 1 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 10, imagen 2 de 3 2009-2015 Toyota Prius Cabin Air Filter Replacement: paso 10, imagen 3 de 3
    • Reinstall the hook on the right side of the glove box by pushing it back over the grey tabs.
Conclusión
Una persona más ha completado esta guía.
Equipo
UC Davis, Team 2-8, Morris Winter 2023 Miembro de UC Davis, Team 2-8, Morris Winter 2023
UCD-MORRIS-W23S2G8
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 60
Ultimos 30 días: 304
Todo El Tiempo: 2,106
