Saltar al contenido principal
2009-2019 Dodge Ram Fog Lights Replacement
Qué necesitas
  1. 2009-2019 Dodge Ram Fog Lights Replacement, Fog Lights: paso 1, imagen 1 de 1
    • Pull the hood latch that is located beneath the steering column.
  2. 2009-2019 Dodge Ram Fog Lights Replacement: paso 2, imagen 1 de 1
    • Push the lever to the left to unlatch the hood of the truck.
  3. 2009-2019 Dodge Ram Fog Lights Replacement: paso 3, imagen 1 de 1
    • Using the ratchet and 10mm socket, disconnect the negative battery terminal by turning counterclockwise.
    • This is done to make sure you do not get shortages.
  4. 2009-2019 Dodge Ram Fog Lights Replacement: paso 4, imagen 1 de 1
    • Disconnect the lighting harness.
    • Do not remove the bulb since the new fog lamp comes with integrated LED bulbs.
  5. 2009-2019 Dodge Ram Fog Lights Replacement: paso 5, imagen 1 de 1
    • Using the ratchet, extension, and the 10 mm socket unscrew the three 10 mm bolts to let the mounting plate free.
  6. 2009-2019 Dodge Ram Fog Lights Replacement: paso 6, imagen 1 de 2 2009-2019 Dodge Ram Fog Lights Replacement: paso 6, imagen 2 de 2
    • Push the tabs inward and pull the mounting bracket towards you to separate the bracket from the fog lamp.
  7. 2009-2019 Dodge Ram Fog Lights Replacement: paso 7, imagen 1 de 1
    • Grab the new fog lamp and insert the three clips into the three holes of the mounting bracket.
  8. 2009-2019 Dodge Ram Fog Lights Replacement: paso 8, imagen 1 de 2 2009-2019 Dodge Ram Fog Lights Replacement: paso 8, imagen 2 de 2
    • Align the three screw holes on the mounting bracket with the holes on the bumper.
  9. 2009-2019 Dodge Ram Fog Lights Replacement: paso 9, imagen 1 de 2 2009-2019 Dodge Ram Fog Lights Replacement: paso 9, imagen 2 de 2
    • Screw on the three 10 mm bolts in the holes.
    • Tighten the bolts by hand first.
    • Tighten the bolts using the 10 mm socket and ratchet.
  10. 2009-2019 Dodge Ram Fog Lights Replacement: paso 10, imagen 1 de 2 2009-2019 Dodge Ram Fog Lights Replacement: paso 10, imagen 2 de 2
    • Reconnect the lighting harness back up to get a power source.
  11. 2009-2019 Dodge Ram Fog Lights Replacement: paso 11, imagen 1 de 2 2009-2019 Dodge Ram Fog Lights Replacement: paso 11, imagen 2 de 2
    • Make sure the fog lamp is where it is desired and in place.
  12. 2009-2019 Dodge Ram Fog Lights Replacement: paso 12, imagen 1 de 1
    • Reconnect the negative battery terminal.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 65
Todo El Tiempo: 2,051
