Saltar al contenido principal
2008 Ford F-150 Air Filter
Qué necesitas
  1. 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: paso 1, imagen 1 de 2 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: paso 1, imagen 2 de 2
    • Turn the engine off.
    • Pull the lever to release the hood.
    • Open the hood.
  2. 2008 Ford F-150 Air Filter: paso 2, imagen 1 de 3 2008 Ford F-150 Air Filter: paso 2, imagen 2 de 3 2008 Ford F-150 Air Filter: paso 2, imagen 3 de 3
    • Find the filter housing unit.
    • Pull the leaver to release the clamp.
    • Move the housing unit out of the way to free the filter.
  3. 2008 Ford F-150 Air Filter: paso 3, imagen 1 de 2 2008 Ford F-150 Air Filter: paso 3, imagen 2 de 2
    • Remove the filter by pulling it straight out.
    • If you are replacing the filter completely, skip to step 7 after completing this step.
  4. 2008 Ford F-150 Air Filter: paso 4, imagen 1 de 1
    • Hit the filter with hand, or on the ground, to remove any large particles that are stuck in the filter.
  5. 2008 Ford F-150 Air Filter: paso 5, imagen 1 de 2 2008 Ford F-150 Air Filter: paso 5, imagen 2 de 2
    • Get a hose with running water.
    • Guide the hose inside the filter, pushing out all the smaller particles.
    • This step will take about 15 minutes, go slow.
  6. 2008 Ford F-150 Air Filter: paso 6, imagen 1 de 2 2008 Ford F-150 Air Filter: paso 6, imagen 2 de 2
    • Place the wet filter outside for it to air dry.
    • Placing the filter in direct sunlight will allow the drying to happen quicker.
  7. 2008 Ford F-150 Air Filter: paso 7, imagen 1 de 1
    • When the filter is completely dry, replace the filter in the housing unit.
  8. 2008 Ford F-150 Air Filter: paso 8, imagen 1 de 3 2008 Ford F-150 Air Filter: paso 8, imagen 2 de 3 2008 Ford F-150 Air Filter: paso 8, imagen 3 de 3
    • Resemble the housing unit and close the hood.
Conclusión
To install a new air filter follow steps 1-3 to remove the old filter and steps 7-8 to install the new air filter
Brennan DuBose
Miembro Desde 09/19/22
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 281
