Saltar al contenido principal
2008-2010 Audi A3 Sportback Key FOB Battery Replacement
Qué necesitas
  1. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: paso 1, imagen 1 de 3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: paso 1, imagen 2 de 3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: paso 1, imagen 3 de 3
    • With the tip of a flat head screwdriver, insert it under the edge of the key fob and push against the back cover to pop it off.
    • Take caution as you apply force to open the cover as the flathead screwdriver is a sharp tool.
  2. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: paso 2, imagen 1 de 2 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: paso 2, imagen 2 de 2
    • Remove the round CR2032 battery from the fob back cover with a plastic spudger or opening tool.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  3. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: paso 3, imagen 1 de 1
    • Insert a new battery and pop the cover back on by hand.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 42
Ultimos 30 días: 206
Todo El Tiempo: 7,309
