Saltar al contenido principal
2008-2011 Saab 9-3 Reverse Light Replacement
Qué necesitas
  1. 2008-2011 Saab 9-3 Reverse Light Replacement, 2008-2011 Saab 9-3 Reverse Light: paso 1, imagen 1 de 2 2008-2011 Saab 9-3 Reverse Light Replacement, 2008-2011 Saab 9-3 Reverse Light: paso 1, imagen 2 de 2
    • Park your car in an area with good light.
  2. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 2, imagen 1 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 2, imagen 2 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 2, imagen 3 de 3
    • Press the button on the key fob or on the front driver-side door to open the trunk of your car.
    • Make sure the trunk lid is open all of the way to avoid being hit.
  3. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 3, imagen 1 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 3, imagen 2 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 3, imagen 3 de 3
    • Use a screwdriver to press down on the center of the trunk lining fasteners.
    • Remove the fasteners.
    • Any screwdriver will work, as the fasteners only needs to be pushed to release them. No screws require removal.
  4. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 4, imagen 1 de 1
    • Gently pull down on the trunk lining to access the light socket.
    • You may need a second pair of hands to help hold down the lining unless all fasteners are removed. If not, the lining will naturally return to its original position.
  5. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 5, imagen 1 de 2 2008-2011 Saab 9-3 Reverse Light Replacement: paso 5, imagen 2 de 2
    • Use light pressure to pull the tab on the light socket towards you.
    • Gently pull down on the light socket to remove.
  6. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 6, imagen 1 de 2 2008-2011 Saab 9-3 Reverse Light Replacement: paso 6, imagen 2 de 2
    • Push down and twist the lightbulb counterclockwise to remove it.
    • Wear gloves when doing this to prevent getting oil from your fingers on the bulb.
  7. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 7, imagen 1 de 1
    • Insert the replacement lightbulb by pushing down and twisting clockwise.
  8. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 8, imagen 1 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 8, imagen 2 de 3 2008-2011 Saab 9-3 Reverse Light Replacement: paso 8, imagen 3 de 3
    • Push the light case back into place.
    • It will click into place when it is securely fastened.
  9. 2008-2011 Saab 9-3 Reverse Light Replacement: paso 9, imagen 1 de 2 2008-2011 Saab 9-3 Reverse Light Replacement: paso 9, imagen 2 de 2
    • Replace the trunk lining and fasteners.
    • Test the reverse light to make sure it's working before driving on public roads.
Linea de Meta
Una persona más ha completado esta guía.
Adriano
Miembro Desde 01/09/24
199 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 102
