Saltar al contenido principal
2008-2013 Subaru Forester Engine Air Intake Filter Replacement
Qué necesitas
  1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: paso 1, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: paso 1, imagen 2 de 2
    • Make sure that the vehicle is turned off before you start.
    • Pull the hood release latch under the driver's dashboard to unlock the hood.
    • Press on the latch under the hood to expose the engine.
  2. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 2, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 2, imagen 2 de 2
    • Locate the engine air intake holding and hose.
  3. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 3, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 3, imagen 2 de 2
    • Unclip and separate the sensor and sensor cable on top of the holding.
    • Move the sensor cable to the side to prevent it from getting in the way.
  4. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 4, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 4, imagen 2 de 2
    • Unlatch the metal clips keeping the holding together.
  5. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 5, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 5, imagen 2 de 2
    • Use a 1/4" flat screwdriver to loosen the metal hose fastener on the engine air intake hose.
    • Do not remove the metal hose fastener. Keep the fastener on the hose for easy reassembly.
    • Remove the engine air intake hose from the holding.
    • Move the engine air intake hose to the side to prevent it from getting in the way.
  6. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 6, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 6, imagen 2 de 2
    • Separate the two sides of the holding from each other.
    • Remove the back panel of the holding to add space to remove the engine air filter.
  7. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 7, imagen 1 de 2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: paso 7, imagen 2 de 2
    • Remove the old engine air intake filter from the holding.
    • Insert the new engine air intake filter into the holding in the same position as the old filter.
Conclusión
Julianna Sober
Miembro Desde 09/29/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 102
Todo El Tiempo: 2,524
