Saltar al contenido principal
2007 Toyota Yaris Cabin Air Filter Replacement
Qué necesitas
  1. 2007 Toyota Yaris Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 1 de 2 2007 Toyota Yaris Cabin Air Filter Replacement, Cabin Air Filter: paso 1, imagen 2 de 2
    • Locate and open the glove compartment.
  2. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 2, imagen 1 de 1
    • Remove the glove compartment by squeezing the sides closer until you are able to remove the compartment.
  3. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 3, imagen 1 de 2 2007 Toyota Yaris Cabin Air Filter Replacement: paso 3, imagen 2 de 2
    • Pinch and pull the compartment that leads to the old air filter.
    • Remove the compartment completely and place it to the side.
  4. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 4, imagen 1 de 1
    • Remove the air filter from the compartment.
  5. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 5, imagen 1 de 3 2007 Toyota Yaris Cabin Air Filter Replacement: paso 5, imagen 2 de 3 2007 Toyota Yaris Cabin Air Filter Replacement: paso 5, imagen 3 de 3
    • Insert the new air filter.
    • Place the compartment back in position to cover the air filter.
    • Push the ridges back into place.
  6. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 6, imagen 1 de 1
    • Lean the glove compartment back into place.
  7. 2007 Toyota Yaris Cabin Air Filter Replacement: paso 7, imagen 1 de 1
    • Push the glove box back to its natural state and enjoy your new air filter!
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 51
Ultimos 30 días: 217
Todo El Tiempo: 496
