Saltar al contenido principal
2007-2012 Acura RDX Engine Air Filter Replacement
Qué necesitas
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 1
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: paso 2, imagen 1 de 1
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: paso 3, imagen 1 de 1
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: paso 4, imagen 1 de 1
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: paso 5, imagen 1 de 2 2007-2012 Acura RDX Engine Air Filter Replacement: paso 5, imagen 2 de 2
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
Conclusión
One the task is done, close the hood and you are good to drive!
Una persona más ha completado esta guía.
Andrew Graham
Miembro Desde 03/23/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 46
Todo El Tiempo: 1,522
