Introducción
Are you having trouble with your windows rolling up or down properly in your 2007-2014 Chevy/GMC SUV or Truck? Don’t sweat it! The problem you are experiencing is common in many vehicles and this guide is exactly what you need. If you follow my guide you can become your own mechanic and finish the job in roughly 10-15 minutes. You’ll be back to rolling down your windows in a few minutes!
Qué necesitas
Using a flat-head screwdriver, wedge underneath the plastic cover to release it from the assembly.
If you continue to have problems with the windows not working properly then it is an issue with either your wiring or motors and should be looked at by a certified technician. Thank you, and I hope my guide helped solve your problem!
2 personas más completaron esta guía.
2 comentarios
I have a 2009 Chevy Silverado. i changed the same panel and everything works except drivers window. any thoughts on how to fix it?
I have the same issue with my 2009 GMC Acadia. Does yours click? If so I found a useful how to guide I'm going to try next on this forum
