Saltar al contenido principal
2006 Honda Shadow Spirit 750 Battery Replacement
Qué necesitas
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: paso 1, imagen 1 de 1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: paso 2, imagen 1 de 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: paso 2, imagen 2 de 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: paso 2, imagen 3 de 3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: paso 3, imagen 1 de 2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: paso 3, imagen 2 de 2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: paso 4, imagen 1 de 1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: paso 5, imagen 1 de 1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: paso 6, imagen 1 de 1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: paso 7, imagen 1 de 1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: paso 8, imagen 1 de 1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: paso 9, imagen 1 de 1
    • Remove the battery from the bike by pulling upwards.
Conclusión
9 personas más completaron esta guía.
Dazarene Cascio
Miembro Desde 10/07/14
736 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-7, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 Miembro
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 92
Todo El Tiempo: 18,813
