Saltar al contenido principal
2006 Ford F-150 Door Handle Cable Replacement
Qué necesitas
  1. 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: paso 1, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: paso 1, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: paso 1, imagen 3 de 3
    • Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
    • Insert the screwdriver into the small opening found at the top of the plastic cover.
    • Carefully tilt the screwdriver upward to remove the plastic cover.
  2. 2006 Ford F-150 Door Handle Cable Replacement: paso 2, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 2, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 2, imagen 3 de 3
    • Remove the two 6 mm hex screws using a 6mm socket.
    • Turn the screwdriver counter-clockwise to loosen and remove the screws.
    • Grab the door handle and remove it from its location.
  3. 2006 Ford F-150 Door Handle Cable Replacement: paso 3, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 3, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 3, imagen 3 de 3
    • Remove the top plastic cover by pulling outward to snap it out of its location.
    • There are not any screws to remove in this part.
  4. 2006 Ford F-150 Door Handle Cable Replacement: paso 4, imagen 1 de 2 2006 Ford F-150 Door Handle Cable Replacement: paso 4, imagen 2 de 2
    • Remove the other plastic cover by pulling outward to snap it out of its location.
  5. 2006 Ford F-150 Door Handle Cable Replacement: paso 5, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 5, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 5, imagen 3 de 3
    • Remove the three 6 mm hex screws off the main door cover using a 6 mm socket. There are two screws at the top and one at the bottom.
    • The panel itself should stay in place even after the screws have been removed.
    • The door panel is maintained in place by plastic hooks behind it.
  6. 2006 Ford F-150 Door Handle Cable Replacement: paso 6, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 6, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 6, imagen 3 de 3
    • Gently, but with a strong force, lift the door cover about an inch or two high. Then, carefully pull it outward.
    • Be careful not to damage the plastic hooks that are keeping the door in place.
  7. 2006 Ford F-150 Door Handle Cable Replacement: paso 7, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 7, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 7, imagen 3 de 3
    • Snap out the upper end of the cable out of its location.
    • The upper end of the cable has a shape of a little ball. The little ball is found by where the door handle was removed.
    • Using a plier, lift the cable high enough so that the little ball can come out through the round opening above it.
  8. 2006 Ford F-150 Door Handle Cable Replacement: paso 8, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 8, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 8, imagen 3 de 3
    • Remove the three T27 hex star screws using a tamper torx screw driver. The screws are found at the bottom of the door.
    • You may need a mechanic creeper to lay under the door.
    • Wear protective goggles if you lay down under the door to do this step.
  9. 2006 Ford F-150 Door Handle Cable Replacement: paso 9, imagen 1 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 9, imagen 2 de 3 2006 Ford F-150 Door Handle Cable Replacement: paso 9, imagen 3 de 3
    • Insert your hand inside the bottom of the door to retrieve the door latch.
  10. 2006 Ford F-150 Door Handle Cable Replacement: paso 10, imagen 1 de 1
    • Remove the end of the cable out of its location.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,921
