Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2006 Dodge RAM Turn Signal Bulb Replacement
Qué necesitas
    1. 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: paso 1, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: paso 1, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: paso 1, imagen 3 de 3
      • Remove the two screws securing the light to the truck using an Allen wrench.
      Pregunta a FixBot
      Agregar Comentario
    2. 2006 Dodge RAM Turn Signal Bulb Replacement: paso 2, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 2, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 2, imagen 3 de 3
      • Pull the light casing out of the socket.
      • The wires exposed at the back of the light case are dangerous to touch as they are exposed electrical wires. Do not interact with them.
      Pregunta a FixBot
      Agregar Comentario
    3. 2006 Dodge RAM Turn Signal Bulb Replacement: paso 3, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 3, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 3, imagen 3 de 3
      • Remove the four screws from the light case.
      Pregunta a FixBot
      Agregar Comentario
    4. 2006 Dodge RAM Turn Signal Bulb Replacement: paso 4, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 4, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 4, imagen 3 de 3
      • Remove the light case from the light bulb holders.
      Pregunta a FixBot
      Agregar Comentario
    5. 2006 Dodge RAM Turn Signal Bulb Replacement: paso 5, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 5, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 5, imagen 3 de 3
      • Replace the light bulb by gently pulling the original light bulb out.
      • Replace the lightbulb with a new one.
      Pregunta a FixBot
      Agregar Comentario
    6. 2006 Dodge RAM Turn Signal Bulb Replacement: paso 6, imagen 1 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 6, imagen 2 de 3 2006 Dodge RAM Turn Signal Bulb Replacement: paso 6, imagen 3 de 3
      • Reattach the lightbulbs to the light casing and put the 4 screws back in.
      • Pop the light casing back into place by making sure the two pointed ends go into the holes.
      • Replace the two screws that secure the light to the truck using an Allen wrench.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Eddie Echegoyen
Miembro Desde 10/18/23
133 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 1-15, Briggs Fall 2023 Miembro de CSU Los Angeles, Team 1-15, Briggs Fall 2023
CSULA-BRIGGS-F23S1G15
1 Miembro
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 624
