Saltar al contenido principal
2006-2008 Isuzu i-Series Wiper Motor Replacement
Qué necesitas
  1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nut Caps: paso 1, imagen 1 de 1
    • Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
  2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: paso 2, imagen 1 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: paso 2, imagen 2 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: paso 2, imagen 3 de 3
    • Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
  3. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: paso 3, imagen 1 de 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: paso 3, imagen 2 de 2
    • Once the necessary nuts are removed, the wiper blade itself can be removed.
    • This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
  4. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: paso 4, imagen 1 de 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: paso 4, imagen 2 de 2
    • Open the hood of the truck for easier access to the wiper cowl.
    • Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
  5. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: paso 5, imagen 1 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: paso 5, imagen 2 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: paso 5, imagen 3 de 3
    • Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
    • Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
    • The wiper cowl is flexible and can therefore be removed a little bit at a time. Take your time.
  6. 2006-2008 Isuzu i-Series Wiper Motor Replacement: paso 6, imagen 1 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement: paso 6, imagen 2 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement: paso 6, imagen 3 de 3
    • Locate the two screws on each side of the wiper assembly.
    • Use a 10mm socket or wrench and remove each screw.
  7. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: paso 7, imagen 1 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: paso 7, imagen 2 de 3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: paso 7, imagen 3 de 3
    • Rotate assembly towards the windshield while starting to remove it from the truck.
    • Unplug the wiring harness located towards the driver's side of the truck.
    • The wire can then be fed through to remove the assembly the rest of the way.
  8. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: paso 8, imagen 1 de 2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: paso 8, imagen 2 de 2
    • Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
    • Remove the three motor bolts with a 10mm wrench or socket (orange circles).
    • The wiper motor is now able to be replaced.
Conclusión
3 personas más completaron esta guía.
Alex
Miembro Desde 10/08/14
211 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-9, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-9, Donnelly Fall 2014
USFT-DONNELLY-F14S1G9
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 3,951
