Saltar al contenido principal
2006-2011 Honda Civic Dome Light Replacement
Qué necesitas
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: paso 1, imagen 1 de 3 2006-2011 Honda Civic Dome Light Replacement, Dome Light: paso 1, imagen 2 de 3 2006-2011 Honda Civic Dome Light Replacement, Dome Light: paso 1, imagen 3 de 3
    • Turn on the dome light by pressing the light.
    • Press in once again, but do not release.
    • Insert a screwdriver or plier into the lifted side of the cover and gently push down.
  2. 2006-2011 Honda Civic Dome Light Replacement: paso 2, imagen 1 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 2, imagen 2 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 2, imagen 3 de 3
    • Remove the bulb by using a flathead screwdriver and gently push down on any side of the bulb.
  3. 2006-2011 Honda Civic Dome Light Replacement: paso 3, imagen 1 de 2 2006-2011 Honda Civic Dome Light Replacement: paso 3, imagen 2 de 2
    • Place your replacement bulb in the center of the two clips and gently push it into place.
  4. 2006-2011 Honda Civic Dome Light Replacement: paso 4, imagen 1 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 4, imagen 2 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 4, imagen 3 de 3
    • Insert one side of the cover into its slot.
    • Gently snap the cover into place.
Conclusión
To reassemble your device, please follow step 4.
Allan
Miembro Desde 10/26/22
159 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 25
Ultimos 30 días: 153
Todo El Tiempo: 1,584
