Saltar al contenido principal
2006-2011 Honda Civic Dome Light Replacement
Qué necesitas
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: paso 1, imagen 1 de 2 2006-2011 Honda Civic Dome Light Replacement, Dome Light: paso 1, imagen 2 de 2
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: paso 2, imagen 1 de 2 2006-2011 Honda Civic Dome Light Replacement: paso 2, imagen 2 de 2
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: paso 3, imagen 1 de 1
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: paso 4, imagen 1 de 2 2006-2011 Honda Civic Dome Light Replacement: paso 4, imagen 2 de 2
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: paso 5, imagen 1 de 1
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: paso 6, imagen 1 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 6, imagen 2 de 3 2006-2011 Honda Civic Dome Light Replacement: paso 6, imagen 3 de 3
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: paso 7, imagen 1 de 1
    • You should now have a functioning dome light.
Conclusión
Hashim
Miembro Desde 10/17/22
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 53
Todo El Tiempo: 634
