Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement
Qué necesitas
  1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: paso 1, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: paso 1, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: paso 1, imagen 3 de 3
    • Pull the hood release in the lower left of the driver's side of your car.
    • Lift the hood of your car until it stays up on its own.
    Pregunta a FixBot
    Agregar Comentario
  2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 2, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 2, imagen 2 de 2
    • Use any size flathead screwdriver to remove the screw plugs that are holding down the engine cover.
    Pregunta a FixBot
    Agregar Comentario
  3. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 3, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 3, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 3, imagen 3 de 3
    • Remove the bottom engine cover.
    Pregunta a FixBot
    Agregar Comentario
  4. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 4, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 4, imagen 2 de 2
    • Use a 1/4" flathead screwdriver to remove the screw holding down the top engine cover.
    Pregunta a FixBot
    Agregar Comentario
  5. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 5, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 5, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 5, imagen 3 de 3
    • Remove the side engine cover.
    Pregunta a FixBot
    Agregar Comentario
  6. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 6, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 6, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 6, imagen 3 de 3
    • Use a 10 mm wrench to remove the washer fluid tube.
    Pregunta a FixBot
    Agregar Comentario
  7. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 7, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 7, imagen 2 de 2
    • Locate the headlight bulb's cover.
    Pregunta a FixBot
    Agregar Comentario
  8. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 8, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 8, imagen 2 de 2
    • Push the metal bar down to release the cover.
    Pregunta a FixBot
    Agregar Comentario
  9. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 9, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 9, imagen 2 de 2
    • Remove the bulb cover.
    Pregunta a FixBot
    Agregar Comentario
  10. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 10, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 10, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 10, imagen 3 de 3
    • Twist the headlight bulb cap counterclockwise (1/4 turn) to detach.
    Pregunta a FixBot
    Agregar Comentario
  11. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 11, imagen 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 11, imagen 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 11, imagen 3 de 3
    • Push the metal clips inward to release the headlight bulb.
    • Pull the bull out of the socket.
    Pregunta a FixBot
    Agregar Comentario
  12. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 12, imagen 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: paso 12, imagen 2 de 2
    • Insert the new headlight bulb.
    • Make sure not to touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Use gloves to avoid oil and salt transfer to the bulb.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Daniel R
Miembro Desde 10/24/23
205 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 12-6, Ribeiro Fall 2023 Miembro de CSU Los Angeles, Team 12-6, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G6
Miembros de 2
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 174
Todo El Tiempo: 7,334
