Saltar al contenido principal
2005 Mazda 6 Electronic Throttle Body Replacement
Qué necesitas
  1. 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: paso 1, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: paso 1, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: paso 1, imagen 3 de 3
    • Open the hood and prop it open.
    • Locate the electronic throttle body.
  2. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 2, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 2, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 2, imagen 3 de 3
    • Detach the electric connection from the electronic throttle body.
    • Unplug the safety pin.
  3. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 3, imagen 1 de 2 2005 Mazda 6 Electronic Throttle Body Replacement: paso 3, imagen 2 de 2
    • Unscrew the clamp that connects the intake hose to the air filter housing.
  4. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 4, imagen 1 de 2 2005 Mazda 6 Electronic Throttle Body Replacement: paso 4, imagen 2 de 2
    • Unscrew the clamp that secures the intake hose with the electronic throttle body.
  5. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 5, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 5, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 5, imagen 3 de 3
    • Disconnect the intake hose from both sides.
  6. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 6, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 6, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 6, imagen 3 de 3
    • Disconnect the upper and lower vacuum hose on the electronic throttle body using a pair of pliers.
  7. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 7, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 7, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 7, imagen 3 de 3
    • Remove the four screws connecting the electronic throttle body to the intake manifold.
  8. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 8, imagen 1 de 2 2005 Mazda 6 Electronic Throttle Body Replacement: paso 8, imagen 2 de 2
    • Place the new electronic throttle body on the intake manifold.
  9. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 9, imagen 1 de 2 2005 Mazda 6 Electronic Throttle Body Replacement: paso 9, imagen 2 de 2
    • Reattach the four screws securing the electronic throttle body with the intake manifold.
  10. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 10, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 10, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 10, imagen 3 de 3
    • Connect the upper vacuum.
    • Connect the lower vacuum hose to the electronic throttle body.
  11. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 11, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 11, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 11, imagen 3 de 3
    • Connect the intake hose on both sides.
    • Screw in the clamp that secures the intake hose to the electronic throttle body.
    • Screw the clamp that secures the intake hose to the air filter housing.
  12. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 12, imagen 1 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 12, imagen 2 de 3 2005 Mazda 6 Electronic Throttle Body Replacement: paso 12, imagen 3 de 3
    • Connect the electric connection to the electronic throttle body.
  13. 2005 Mazda 6 Electronic Throttle Body Replacement: paso 13, imagen 1 de 2 2005 Mazda 6 Electronic Throttle Body Replacement: paso 13, imagen 2 de 2
    • The electronic throttle body replacement is done.
Linea de Meta
Una persona más ha completado esta guía.
Yefri Gonzalez
Miembro Desde 04/04/22
244 Reputación
1 Guía escrita
Equipo
Un comentario
Bonjour j'ai un Mazda 6 de moteur Essence avec moi mais sa consomme trop et Quel est la solution pour d'autre me disent de changer le catalyseur d'autres me disent de changer la bougie
Sidi mohamed Coulibaly - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,089
