Saltar al contenido principal
2005 Honda Pilot Rear Strut Replacement
Qué necesitas
  1. 2005 Honda Pilot Rear Strut Replacement, Rear Struts: paso 1, imagen 1 de 1
    • Begin by placing a support beneath the trunk that takes all the weight of the trunk.
  2. 2005 Honda Pilot Rear Strut Replacement: paso 2, imagen 1 de 1
    • Insert the flat head screwdriver under the clip, at the top of the strut, and lift the clip until it pops off completely.
  3. 2005 Honda Pilot Rear Strut Replacement: paso 3, imagen 1 de 1
    • Now, insert the flat head screwdriver under the clip, at the bottom of the strut, and lift the clip until it pops off completely.
  4. 2005 Honda Pilot Rear Strut Replacement: paso 4, imagen 1 de 1
    • Line up the ball and the socket pieces of your new strut.
  5. 2005 Honda Pilot Rear Strut Replacement: paso 5, imagen 1 de 1
    • Use force to push the strut and connect the ball and socket joint.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 209
