Saltar al contenido principal
2005-2012 Toyota Yaris Spark Plug Replacement
Qué necesitas
  1. 2005-2012 Toyota Yaris Spark Plug Replacement, Spark Plug: paso 1, imagen 1 de 2 2005-2012 Toyota Yaris Spark Plug Replacement, Spark Plug: paso 1, imagen 2 de 2
    • Remove the four bolts from the engine cover using a 10 mm socket wrench.
    • Additionally, you can use the wrench to loosen the bolts and then swap for your hands or a spinner handle to completely unscrew them.
  2. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 2, imagen 1 de 2 2005-2012 Toyota Yaris Spark Plug Replacement: paso 2, imagen 2 de 2
    • Lift the cap off and set it to the side.
    • You will see four ignition coils. For this tutorial, we will only replace one of the sockets.
  3. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 3, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 3, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 3, imagen 3 de 3
    • Remove the ignition coil connector by pushing down on the end of the clip and unplugging it.
    • Unscrew the bolt on the other end of the socket plug using the 10 mm socket wrench.
  4. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 4, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 4, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 4, imagen 3 de 3
    • Remove the ignition coil to reveal the spark plug cavity.
  5. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 5, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 5, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 5, imagen 3 de 3
    • Remove the adapter and 10mm socket from the socket wrench and replace it with the 6" extension adapter and spark plug socket
  6. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 6, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 6, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 6, imagen 3 de 3
    • Too much force can cause your spark plug to crack. Unscrew it carefully to ensure no debris falls into the hole.
    • Insert a 6" extension adapter and spark plug socket wrench into the cavity where your spark plug is located. Make sure it reaches and securely grabs onto the spark plug.
    • Remove the spark plug by pulling the socket wrench towards you, and loosen it until it unscrews completely.
    • To be safer, start by using the wrench to loosen it, then remove the wrench handle and unscrew it the rest of the way with your hands.
    • Lift the wrench and the spark plug out of the cavity.
  7. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 7, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 7, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 7, imagen 3 de 3
    • After you remove the old spark plug, take out your new spark plug and remove its plastic protector.
  8. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 8, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 8, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 8, imagen 3 de 3
    • Once you remove the white protector, take out the spark plug boot protector and open it to spread its lubricant across the screw area of the new spark plug.
    • Anti-Seize Lubricant is used to allow for easy spark plug removal in the future.
  9. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 9, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 9, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 9, imagen 3 de 3
    • Make sure you tighten enough to minimize the risk of the spark plug being removed from the engine.
    • Fit your new spark plug into the socket, and insert it into the cavity.
    • Tighten the spark plug by pushing the wrench away from you, doing so until it's completely screwed in.
    • To avoid damaging the spark plug while tightening it, start by screwing in the plug with your hands, then add the wrench handle and tighten until it's secure.
  10. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 10, imagen 1 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 10, imagen 2 de 3 2005-2012 Toyota Yaris Spark Plug Replacement: paso 10, imagen 3 de 3
    • Insert the ignition coil back into the cavity, plug in the connector, and screw in the bolt to secure it.
    • If your ignition coil connector's tab broke like this one did, you can use zip-ties to secure it or replace it. (Part #: 90980-11885)
  11. 2005-2012 Toyota Yaris Spark Plug Replacement: paso 11, imagen 1 de 1
    • If more than one spark plug is damaged, repeat steps 5-11 for the rest of them.
Linea de Meta
4 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 20
Ultimos 7 días: 107
Ultimos 30 días: 449
Todo El Tiempo: 2,025
