Saltar al contenido principal
2005-2012 Toyota RAV4 Headlight Replacement
  1. 2005-2012 Toyota RAV4 Headlight Replacement, Headlight: paso 1, imagen 1 de 1
    • Turn off your car, use your emergency break to secure the car and pop open the hood.
    • Make sure the engine is not hot before working under the hood of the car.
  2. 2005-2012 Toyota RAV4 Headlight Replacement: paso 2, imagen 1 de 2 2005-2012 Toyota RAV4 Headlight Replacement: paso 2, imagen 2 de 2
    • Under the hood of the car, locate a black cable towards the grille on the drivers side that leads to the back of the headlight. The bulb is located here.
  3. 2005-2012 Toyota RAV4 Headlight Replacement: paso 3, imagen 1 de 3 2005-2012 Toyota RAV4 Headlight Replacement: paso 3, imagen 2 de 3 2005-2012 Toyota RAV4 Headlight Replacement: paso 3, imagen 3 de 3
    • Turn the bulb counter-clockwise using your hand and gently pull the headlight out.
  4. 2005-2012 Toyota RAV4 Headlight Replacement: paso 4, imagen 1 de 2 2005-2012 Toyota RAV4 Headlight Replacement: paso 4, imagen 2 de 2
    • The headlight is attached to a plug that has a clip. Push down on the clip and pull the bulb out at the same time with the opposite hand.
  5. 2005-2012 Toyota RAV4 Headlight Replacement: paso 5, imagen 1 de 3 2005-2012 Toyota RAV4 Headlight Replacement: paso 5, imagen 2 de 3 2005-2012 Toyota RAV4 Headlight Replacement: paso 5, imagen 3 de 3
    • Slide the new bulb into that same plug until you hear a click.
  6. 2005-2012 Toyota RAV4 Headlight Replacement: paso 6, imagen 1 de 2 2005-2012 Toyota RAV4 Headlight Replacement: paso 6, imagen 2 de 2
    • Put the bulb into the same hole that it was removed from and turn clockwise until you hear another click. You are done!
Conclusión
3 personas más completaron esta guía.
Un comentario
This is a headlight BULB replacement, not a headlight replacement. Please consider changing the title, which is misleading. Thank you.
Barb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 38
Ultimos 30 días: 229
Todo El Tiempo: 9,558
