Saltar al contenido principal
2004 Toyota Sienna Sliding Door Motor Replacement
Qué necesitas
Resumen del Video
  1. 2004 Toyota Sienna Sliding Door Motor Replacement, Sliding Door Motor: paso 1, imagen 1 de 1
    • First, test both sliding doors to identify the problem with the driver's side door
    • source.
  2. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 2, imagen 1 de 1
    • Remove the second-row seat to access the door panel
    • source.
  3. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 3, imagen 1 de 1
    • Remove the two Phillips screws holding the door panel in place
    • source.
  4. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 4, imagen 1 de 1
    • Carefully remove the door panel by lifting it out and disconnect the power window
    • source.
  5. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 5, imagen 1 de 1
    • Close the door and observe the actuator motor on the working passenger side door for comparison
    • source.
  6. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 6, imagen 1 de 1
    • On the driver's side door, test the voltage to confirm it's an issue with the actuator motor and not an electrical problem
    • source.
  7. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 7, imagen 1 de 1
    • Order a replacement actuator motor (Part #s in the video) and wait for its arrival
    • source.
  8. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 8, imagen 1 de 1
    • Remove the window regulator by lowering the window and accessing the bolts through the portholes
    • source.
  9. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 9, imagen 1 de 1
    • Remove the actuator motor by grinding off the stripped Phillips screws with a Dremel tool or using vice grips
    • source.
  10. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 10, imagen 1 de 1
    • Replace the actuator motor with the new part, using socket screws from wall sockets or light switches if necessary
    • source.
  11. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 11, imagen 1 de 1
    • Reassemble the window regulator and test the window function
    • source.
  12. 2004 Toyota Sienna Sliding Door Motor Replacement: paso 12, imagen 1 de 1
    • Test the sliding door in manual mode and then in power mode
    • source.
Conclusión
Una persona más ha completado esta guía.
eCuration
Miembro Desde 05/19/17
376,693 Reputación
234 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,277 Guías creadas
Un comentario
Great instructions! I was able to fix sliding door.
However, the window doesn’t scroll up all the way and it wiggles if you pull on it.
What did did I do wrong? Any suggestions are appreciated.
Nara Lim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 35
Todo El Tiempo: 2,206
