Saltar al contenido principal
2004 Toyota Camry Engine Air Filter Replacement
  1. 2004 Toyota Camry Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 2 2004 Toyota Camry Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 2 de 2
    • Make sure the car is in park with the engine off.
  2. 2004 Toyota Camry Engine Air Filter Replacement: paso 2, imagen 1 de 3 2004 Toyota Camry Engine Air Filter Replacement: paso 2, imagen 2 de 3 2004 Toyota Camry Engine Air Filter Replacement: paso 2, imagen 3 de 3
    • Pop the hood of the car which is located next to the steering wheel.
  3. 2004 Toyota Camry Engine Air Filter Replacement: paso 3, imagen 1 de 2 2004 Toyota Camry Engine Air Filter Replacement: paso 3, imagen 2 de 2
    • Locate the airbox of the vehicle.
  4. 2004 Toyota Camry Engine Air Filter Replacement: paso 4, imagen 1 de 3 2004 Toyota Camry Engine Air Filter Replacement: paso 4, imagen 2 de 3 2004 Toyota Camry Engine Air Filter Replacement: paso 4, imagen 3 de 3
    • Undo the clips that are holding the top of the airbox.
  5. 2004 Toyota Camry Engine Air Filter Replacement: paso 5, imagen 1 de 1
    • Make sure the air filter is the same as the one that is in the vehicle.
  6. 2004 Toyota Camry Engine Air Filter Replacement: paso 6, imagen 1 de 1
    • Remove the old air filter.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 65
