Saltar al contenido principal
2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly
Qué necesitas
  1. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, Stereo Unit: paso 1, imagen 1 de 1
    • This is the front panel of the 2004 Mazda 3 Stereo-CD Player. It's listed under the model number: BN85-66-9RXA.
  2. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 2, imagen 1 de 1
    • On the right side of the unit, designated by the letter R, remove 6 screws using a Phillips #2 screwdriver.
  3. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 3, imagen 1 de 1
    • On the left side of unit, designated by the letter L, remove 6 screws using a Phillips #2 screwdriver.
    • Gently pull on the cable to disconnect it from the front panel.
    • Now you can fully detach the front panel as well as the LCD display from the unit.
  4. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 4, imagen 1 de 1
    • On the top of the unit, remove 2 screws with a Phillips #2 screwdriver.
    • Lift and remove the top case from the unit.
  5. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 5, imagen 1 de 1
    • On the bottom of the unit, remove 2 screws with the Phillips #2 screwdriver.
  6. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 6, imagen 1 de 1
    • On the back of the unit, remove 8 screws with a Phillips #2 screwdriver.
    • Remove 1 screw with a Phillips #1 screwdriver.
    • Pull off both the bottom and top metal plates.
  7. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 7, imagen 1 de 1
    • On the front of the unit, remove 4 screws with a Phillips #2 screwdriver.
  8. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 8, imagen 1 de 1
    • On the left side of the unit, designated by the letter L, remove 2 screws with a Phillips #2 screwdriver.
  9. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 9, imagen 1 de 1
    • On the right side of the unit, designated by the letter R, remove 2 screws with a Phillips #2 screwdriver.
    • Pull the front metal plate off the unit. Then lift the CD drive from the lower metal case.
  10. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, CD Drive: paso 10, imagen 1 de 1
    • Remove 2 screws with a Phillips #1 screwdriver from the front of the CD drive.
    • Very gently pull apart the top metal case from the CD drive without damaging the ribbon cable.
  11. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: paso 11, imagen 1 de 1
    • Gently pull the ribbon cable from the connector on the CD drive logic board.
Conclusión
2 personas más completaron esta guía.
Robin Nystrom
Miembro Desde 06/13/16
182 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 5,005
