Saltar al contenido principal
2004 Honda Accord Speed Sensor Gear Replacement
Qué necesitas
  1. 2004 Honda Accord Speed Sensor Gear Replacement, Speed Sensor Gear: paso 1, imagen 1 de 2 2004 Honda Accord Speed Sensor Gear Replacement, Speed Sensor Gear: paso 1, imagen 2 de 2
    • Prop open the hood of the car with the hood prop rod.
  2. 2004 Honda Accord Speed Sensor Gear Replacement: paso 2, imagen 1 de 2 2004 Honda Accord Speed Sensor Gear Replacement: paso 2, imagen 2 de 2
    • Pull out the large air tube of the engine by hand.
    • Put this large tube to the side.
  3. 2004 Honda Accord Speed Sensor Gear Replacement: paso 3, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 3, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 3, imagen 3 de 3
    • With the grip on the covered part of the cables, lift the battery cables off the terminal posts of the battery.
    • Lift the right battery cable off the terminal post of the battery, then lift the left battery cable off the terminal post.
    • Be careful not to touch the metal of the car battery, especially when cables are still connected.
  4. 2004 Honda Accord Speed Sensor Gear Replacement: paso 4, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 4, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 4, imagen 3 de 3
    • Lift the engine tubes out of the way to see the speedometer gear sensor with the 12.0 mm flange bolt and plug attached next to each other.
  5. 2004 Honda Accord Speed Sensor Gear Replacement: paso 5, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 5, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 5, imagen 3 de 3
    • Fit a 12-mm socket wrench over the 12.0 mm flange bolt of the speedometer gear sensor.
    • If reaching the bolt is difficult, attach a socket wrench extension to the socket wrench to make the bolt easier to reach
    • Turn the socket wrench in a counter-clockwise direction to loosen the bolt.
    • Once the flange bolt is loose enough, twist the bolt off by hand.
  6. 2004 Honda Accord Speed Sensor Gear Replacement: paso 6, imagen 1 de 1
    • Put the removed 12.0 mm flange bolt to the side.
    • The bolt that holds the speedometer gear sensor system in place is a 12 x 35 mm flange hex bolt.
  7. 2004 Honda Accord Speed Sensor Gear Replacement: paso 7, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 7, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 7, imagen 3 de 3
    • Use a pair of standard flat pliers to gently shift the speedometer gear sensor away from the bolt opening.
    • Remove the speedometer gear sensor from the slot.
  8. 2004 Honda Accord Speed Sensor Gear Replacement: paso 8, imagen 1 de 2 2004 Honda Accord Speed Sensor Gear Replacement: paso 8, imagen 2 de 2
    • Pinch the lock on the speed sensor plug to unlock the plug from the speedometer gear.
    • If disconnecting the plug by hand is difficult, gently use the standard flat pliers to apply pressure on the lock.
  9. 2004 Honda Accord Speed Sensor Gear Replacement: paso 9, imagen 1 de 2 2004 Honda Accord Speed Sensor Gear Replacement: paso 9, imagen 2 de 2
    • Once the plug is disconnected from the speedometer gear, remove the speedometer gear system from the car.
  10. 2004 Honda Accord Speed Sensor Gear Replacement: paso 10, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 10, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 10, imagen 3 de 3
    • Gently pry out the metal pin on the side of the speedometer system, being careful not to bend the pin too much.
    • This is the pin holding the speedometer sensor gear together.
    • Once the pin is loose, pull the pin out of the gear and put the pin to the side.
  11. 2004 Honda Accord Speed Sensor Gear Replacement: paso 11, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 11, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 11, imagen 3 de 3
    • Pull the gear out of the speedometer sensor by hand.
  12. 2004 Honda Accord Speed Sensor Gear Replacement: paso 12, imagen 1 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 12, imagen 2 de 3 2004 Honda Accord Speed Sensor Gear Replacement: paso 12, imagen 3 de 3
    • Slide a new gear into the speedometer sensor.
Conclusión
Kathya Nava
Miembro Desde 04/02/23
205 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 49
Todo El Tiempo: 374
