Saltar al contenido principal
2004-2008 Mazda RX-8 Battery Replacement
Qué necesitas
  1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: paso 1, imagen 1 de 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: paso 1, imagen 2 de 3 2004-2008 Mazda RX-8 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Find black tabs that lock Battery cover into place.
    • The tabs should snap off easily.
  2. 2004-2008 Mazda RX-8 Battery Replacement: paso 2, imagen 1 de 2 2004-2008 Mazda RX-8 Battery Replacement: paso 2, imagen 2 de 2
    • Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
    • It is vital to disconnect the negative terminal before interacting with the battery. Make sure not to bridge the two terminals with your wrench or other tools.
    • Remove the terminals once nuts are completely loose.
  3. 2004-2008 Mazda RX-8 Battery Replacement: paso 3, imagen 1 de 1
    • Remove Battery terminals.
  4. 2004-2008 Mazda RX-8 Battery Replacement: paso 4, imagen 1 de 1
    • Using the 10mm Wrench remove gold nuts that hold the retention bar in place.
  5. 2004-2008 Mazda RX-8 Battery Replacement: paso 5, imagen 1 de 1
    • After removing the bar pull the dead battery out using the black straps.
Conclusión
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
2 personas más completaron esta guía.
Gerrit Mouw
Miembro Desde 05/01/15
253 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-4, Regan Spring 2015 Miembro de Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 Miembros
5 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 56
Todo El Tiempo: 15,805
