Saltar al contenido principal
2004-2015 Nissan Frontier Tail Light Replacement
Qué necesitas
  1. 2004-2015 Nissan Frontier Tail Light Replacement, Tail Light Bulb: paso 1, imagen 1 de 2 2004-2015 Nissan Frontier Tail Light Replacement, Tail Light Bulb: paso 1, imagen 2 de 2
    • Open the tailgate by lifting the center handle.
  2. 2004-2015 Nissan Frontier Tail Light Replacement: paso 2, imagen 1 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 2, imagen 2 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 2, imagen 3 de 3
    • Unscrew the two Phillips #1 screws.
  3. 2004-2015 Nissan Frontier Tail Light Replacement: paso 3, imagen 1 de 2 2004-2015 Nissan Frontier Tail Light Replacement: paso 3, imagen 2 de 2
    • Pull the tail light assembly out of its place within the frame of the vehicle.
  4. 2004-2015 Nissan Frontier Tail Light Replacement: paso 4, imagen 1 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 4, imagen 2 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 4, imagen 3 de 3
    • Twist the bulb within its socket counter-clockwise, then remove it from the inner assembly.
    • Remove the bulb by pulling directly out of the socket.
  5. 2004-2015 Nissan Frontier Tail Light Replacement: paso 5, imagen 1 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 5, imagen 2 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 5, imagen 3 de 3
    • Gently place your replacement bulb into the socket.
    • Insert the socket back into the tail light assembly, then twist clockwise until secure.
  6. 2004-2015 Nissan Frontier Tail Light Replacement: paso 6, imagen 1 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 6, imagen 2 de 3 2004-2015 Nissan Frontier Tail Light Replacement: paso 6, imagen 3 de 3
    • Gently place the tail light assembly back into its original position.
    • Screw back in the Phillips #1 screws.
  7. 2004-2015 Nissan Frontier Tail Light Replacement: paso 7, imagen 1 de 2 2004-2015 Nissan Frontier Tail Light Replacement: paso 7, imagen 2 de 2
    • Close the tail gate.
    • Turn on your truck to ensure that the lights are in working condition.
Conclusión
Alejandro Jimenez
Miembro Desde 10/24/23
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 76
Todo El Tiempo: 525
