Saltar al contenido principal
2003 Toyota Solara Tail Light Replacement
Qué necesitas
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: paso 1, imagen 1 de 1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: paso 2, imagen 1 de 3 2003 Toyota Solara Tail Light Replacement: paso 2, imagen 2 de 3 2003 Toyota Solara Tail Light Replacement: paso 2, imagen 3 de 3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: paso 3, imagen 1 de 2 2003 Toyota Solara Tail Light Replacement: paso 3, imagen 2 de 2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: paso 4, imagen 1 de 2 2003 Toyota Solara Tail Light Replacement: paso 4, imagen 2 de 2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: paso 5, imagen 1 de 3 2003 Toyota Solara Tail Light Replacement: paso 5, imagen 2 de 3 2003 Toyota Solara Tail Light Replacement: paso 5, imagen 3 de 3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: paso 6, imagen 1 de 2 2003 Toyota Solara Tail Light Replacement: paso 6, imagen 2 de 2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
Conclusión
To reassemble the tail lamp, follow these instructions in reverse order.
2 personas más completaron esta guía.
Equipo
UC Davis, Team S2-G2, Cole Spring 2017 Miembro de UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 93
Todo El Tiempo: 2,929
