Introducción
This is a guide on how to replace the low beam lights on a 2004 Chevrolet Silverado. The headlight is held in place by clips. You will not needs any tools to complete this project beside the replacement bulbs. Having a rag or terry cloth is best for handling the bulb.
Qué necesitas
First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
Pinch the blue clips and remove them from the back of the wiring harness.
After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
Unbox your new low beam light, and insert it into the same hole you took the old one out of.
Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
Begin to replace the headlight housing back into its original place by tucking in the wires.
Grab the pin that you took out at the beginning and insert it back into the housing unit.
Align the housing back with the guide holes for the pin.
To replace the other light bulb just follow the same steps as above.
5 personas más completaron esta guía.
Un comentario
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
