Introducción
Replace the engine's air filter every 15,000 miles.
Herramientas
Partes
No se especificaron partes.
Locate the hood latch beside the driver's side door, right next to the left foot rest.
Identify the engine's air duct hose.
Remove the emission hose by gently wiggling it out of place.
Replace the old filter with the new filter.
Screw down the air filter housing cap. Connect air dust, emission, and smog hoses.
To reassemble your device, follow instructions in steps 1-5 in reverse order.
21 personas más completaron esta guía.
4 comentarios
Okay, I have an Acura TSX (Euro Accord) with the K24A engine, which is similar, and can assure you that you do not need to remove all these connections and hoses just to open the engine air cleaner . The AIR CLEANER COVER (where the filter lives) can be gently lifted up sufficiently to open up, remove the AIR CLEANER ELEMENT ASSY (filter), vacuum out debris from AIR CLEANER CASE, and install a new filter.
For a 2006 Accord L4, you definitely need to remove the air intake hose as the front lip of the air cleaner box will not clear the inner fender by about 1/4" on the left side. Never had problems with any other newer or older hondas and toyotas with having to remove the air intake hose to open the air cleaner box. This is why I came here for advice. thanks OP.
emission hose where can I find it at ? Mine broke
You use metric tools on Hondas because they are a foreign car. Use an 8mm socket with an extension to remove the screws from the air filter cover.
