Saltar al contenido principal
2003-2008 Toyota Corolla Headlight Bulb Replacement
Qué necesitas
  1. 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 2 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 2 de 2
    • Locate the handle to open the hood. It will be on the driver side of the car to the left.
    • Pull up on the handle and the hood should pop open a small amount.
  2. 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 2, imagen 1 de 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 2, imagen 2 de 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 2, imagen 3 de 3
    • Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
    • Locate the prop and insert it into the hole in the hood.
  3. 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 3, imagen 1 de 1
    • Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
  4. 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 4, imagen 1 de 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 4, imagen 2 de 3 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 4, imagen 3 de 3
    • Twist assembly 45 degrees counter clockwise and pull straight out.
    • Be careful not to touch the glass on the new bulb. The oils from your hand could cause premature bulb failure.
  5. 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 5, imagen 1 de 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 5, imagen 2 de 2
    • Lift up on the latch and pull. The bulb will come free from the wires.
  6. 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 6, imagen 1 de 2 2003-2008 Toyota Corolla Headlight Bulb Replacement: paso 6, imagen 2 de 2
    • Locate the other bulb, and repeat steps 3-5 to remove it.
Conclusión
11 personas más completaron esta guía.
Equipo
Cal Poly, Team 17-4, Green Fall 2015 Miembro de Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
3 Miembros
4 Guías creadas
Un comentario
https://youtu.be/GHezj9nmbxE
Change headlight on your corolla in under one minute. So easy.
baxta777 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 81
Ultimos 30 días: 410
Todo El Tiempo: 92,893
