Saltar al contenido principal
2002 Toyota Solara Headlight Bulb Replacement
  1. 2002 Toyota Solara Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 1
    • Open the hood of the car by pulling the tab near the driver side floor.
  2. 2002 Toyota Solara Headlight Bulb Replacement: paso 2, imagen 1 de 3 2002 Toyota Solara Headlight Bulb Replacement: paso 2, imagen 2 de 3 2002 Toyota Solara Headlight Bulb Replacement: paso 2, imagen 3 de 3
    • Locate where to access the bulb.
    • Remove the electrical connector by placing index finger underneath and thumb on top, pulling with steady force until it is disconnected.
  3. 2002 Toyota Solara Headlight Bulb Replacement: paso 3, imagen 1 de 2 2002 Toyota Solara Headlight Bulb Replacement: paso 3, imagen 2 de 2
    • Remove rubber grommet surrounding the headlight bulb and set it aside.
  4. 2002 Toyota Solara Headlight Bulb Replacement: paso 4, imagen 1 de 2 2002 Toyota Solara Headlight Bulb Replacement: paso 4, imagen 2 de 2
    • Release the headlight bulb by turning the housing counterclockwise and pulling until the bulb is released. Once removed, replace the headlight bulb.
Conclusión
Victoria Jones
Miembro Desde 03/30/20
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 718
