Saltar al contenido principal
2002 Kawasaki KLR650 Carburetor Rebuild
Qué necesitas
  1. 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: paso 1, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: paso 1, imagen 2 de 2
    • Use an 3 mm Allen wrench to loosen the drain screw on lower portion of bowl.
    • Remove old fuel left inside of bowl.
  2. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 2, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four screws on the outside of the bowl.
    • Remove the bowl from the carburetor and take out the gasket from the bowl.
  3. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 3, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 3, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 3, imagen 3 de 3
    • Remove the pilot jet using a flat head screwdriver.
  4. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 4, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 4, imagen 2 de 2
    • Remove the main jet using a flat head screwdriver.
  5. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 5, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 5, imagen 2 de 2
    • Remove the main jet sleeve using an 8 mm combination wrench.
  6. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 6, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 6, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 6, imagen 3 de 3
    • Push out the retaining pin holding in the float and float seat.
    • Remove this assembly from the carburetor.
  7. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 7, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 7, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 7, imagen 3 de 3
    • Flip the carburetor around and remove the four screws securing the top housing using a Phillips #1 screwdriver.
    • Note that this is spring loaded.
  8. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 8, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 8, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 8, imagen 3 de 3
    • Pull up on the diaphragm carefully to remove the diaphragm and slide.
    • Take out the needle and plastic needle retainer.
  9. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 9, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 9, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 9, imagen 3 de 3
    • Replace the needle and reassemble the slide.
    • Insert the slide assembly back into the carburetor.
    • The needle needs to be lined up with the hole in the carburetor. Make sure that the diaphragm makes a good seal in the carburetor gasket groove.
    • Insert the spring into the slide assembly and put the plastic housing back on.
    • Maintain pressure while screwing the four Phillips screws in the housing since it is spring loaded.
    • Tighten the screws in a diagonal pattern to ensure that the plastic housing is sealed properly.
  10. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 10, imagen 1 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 10, imagen 2 de 3 2002 Kawasaki KLR650 Carburetor Rebuild: paso 10, imagen 3 de 3
    • Place the new float seat onto the float.
    • Place the float assembly into the carburetor and slide the retaining pin back into its hole to secure the assembly.
    • Make sure that the float can move freely.
  11. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 11, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 11, imagen 2 de 2
    • Insert the new pilot jet into the carburetor. Tighten it with a flathead screwdriver.
    • Do not over tighten the pilot jet as it is made of brass and may strip easily.
  12. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 12, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 12, imagen 2 de 2
    • Reinsert the main sleeve and tighten with an 8 mm combination wrench.
    • Insert the new main jet into the main jet sleeve. Tighten using a flathead screwdriver.
    • Do not over tighten as this is made out of brass and may strip easily.
  13. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 13, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 13, imagen 2 de 2
    • Insert the new gasket into the bowl gasket groove.
    • Use a Phillips #1 screwdriver to replace the four screws securing the bowl to the carburetor.
    • Tighten in a diagonal pattern to ensure that the bowl is sealed properly.
  14. 2002 Kawasaki KLR650 Carburetor Rebuild: paso 14, imagen 1 de 2 2002 Kawasaki KLR650 Carburetor Rebuild: paso 14, imagen 2 de 2
    • Use a 3 mm Allen wrench to tighten drain screw at the bottom of carburetor.
Conclusión
Una persona más ha completado esta guía.
Shawn Marcoux
Miembro Desde 03/24/21
253 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 68
Todo El Tiempo: 1,613
