Introducción
After extended windshield wiper use from storms and weather, your windshield wiper blades will become worn. There are two signs that it is time to replace your windshield wiper blades.
1. When a streaking noise is made when using your windshield wipers.
2. When your windshield wipers do not remove most of the water from your windshield.
It is very important to have working windshield wipers to prevent you from getting into an accident and potentially harming others.
This guide will demonstrate how to remove worn windshield wiper blades on a 2006 Toyota Camry LE and insert new wiper blades.
All that is needed to perform this repair is a new set of windshield wiper blades with the correct measurements for your front windshield!
Qué necesitas
Congratulations, you have properly replaced your windshield wipers!
