Saltar al contenido principal
2002-2006 Toyota Camry Key Fob Battery Replacement
Qué necesitas
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 1 de 2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: paso 1, imagen 2 de 2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 2, imagen 1 de 1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 3, imagen 1 de 1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 4, imagen 1 de 2 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 4, imagen 2 de 2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 5, imagen 1 de 1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: paso 6, imagen 1 de 1
    • Reassemble the fob, using your hands to press the two parts together.
Conclusión
Salman Abu Mazen
Miembro Desde 09/27/21
140 Reputación
1 Guía escrita
Equipo
UM-Willis-F21S51G7 Miembro de UM-Willis-F21S51G7
Community
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 50
Ultimos 30 días: 241
Todo El Tiempo: 5,610
