Introducción
The inside cabin air filter is essential to filtering the outside air of pollutants before it enters the vehicle. It is suggested that the filter be replaced once a year.
Follow the video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
Qué necesitas
Instrucciones de Vídeo
Casi Terminas!
Conclusión
Un comentario
only works on 2002, not 2003 thru 2006. They have a completely different plastic mold under the glove box and you cannot get tot he air filter, or whatever filter they replaced the air filter with. I have a 2006 and the video doesn’t work for it. i have read that Cadillac supposedly replaced the air filter with something more perm, but I can see some type of filter thru a small air hole int he plastic. Only way to replace that in any way is to cut thru the plastic, which you would need a dremel
William Novotny - Contestar
