Saltar al contenido principal
2002-2006 Acura Integra Windshield Wipers Replacement
Qué necesitas
  1. 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: paso 1, imagen 1 de 3 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: paso 1, imagen 2 de 3 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: paso 1, imagen 3 de 3
    • Use the tape measure to measure the length of the wiper blades from top to bottom.
    • This will help you determine the correct size of replacement wipers that you will need.
  2. 2002-2006 Acura Integra Windshield Wipers Replacement: paso 2, imagen 1 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 2, imagen 2 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 2, imagen 3 de 3
    • Lift the windshield wiper off the windshield.
    • Place a towel underneath the wiper to prevent damage to the windshield if the wiper is dropped.
    • Avoid lifting the windshield wiper too far back; doing so can cause damage to what helps the wiper stay against the windshield.
  3. 2002-2006 Acura Integra Windshield Wipers Replacement: paso 3, imagen 1 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 3, imagen 2 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 3, imagen 3 de 3
    • Lift open the clip above the wiper with one hand while holding the wiper arm up with the other.
    • Opening this clip will allow us to slide the wiper off for the next step.
  4. 2002-2006 Acura Integra Windshield Wipers Replacement: paso 4, imagen 1 de 2 2002-2006 Acura Integra Windshield Wipers Replacement: paso 4, imagen 2 de 2
    • Grab the wiper with one hand while holding the wiper arm up with the other.
    • Slide the wiper down.
    • Once unhooked, pull the wiper back and away from the wiper arm to remove the wiper.
  5. 2002-2006 Acura Integra Windshield Wipers Replacement: paso 5, imagen 1 de 2 2002-2006 Acura Integra Windshield Wipers Replacement: paso 5, imagen 2 de 2
    • Place the replacement wiper against the wiper arm with the hooking mechanism facing the hook of the wiper arm.
    • Slide the wiper up, thus putting it into place.
  6. 2002-2006 Acura Integra Windshield Wipers Replacement: paso 6, imagen 1 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 6, imagen 2 de 3 2002-2006 Acura Integra Windshield Wipers Replacement: paso 6, imagen 3 de 3
    • Once the wiper is slid up all the way, grab the top clip of the wiper.
    • Close the clip until a click is heard.
    • Remove the towel and lower the wiper arm down gently.
Conclusión
Follow these instructions for the second windshield wiper.
Una persona más ha completado esta guía.
Brian Gonzalez
Miembro Desde 12/05/22
154 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 120
