Saltar al contenido principal
2002-2006 Acura Integra Hatch Strut Replacement
Qué necesitas
  1. 2002-2006 Acura Integra Hatch Strut Replacement, Hatch Strut: paso 1, imagen 1 de 1
  2. 2002-2006 Acura Integra Hatch Strut Replacement: paso 2, imagen 1 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 2, imagen 2 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 2, imagen 3 de 3
    • Go to the rear of the vehicle.
    • Pull up on the trunk handle to lift open the trunk.
  3. 2002-2006 Acura Integra Hatch Strut Replacement: paso 3, imagen 1 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 3, imagen 2 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 3, imagen 3 de 3
    • Prop open hatch or have someone help support the hatch weight.
    • Remove the upper ball mount.
    • Turn the upper ball mount counterclockwise with a 12mm wrench.
    • It will pop off when it's completely unscrewed.
  4. 2002-2006 Acura Integra Hatch Strut Replacement: paso 4, imagen 1 de 2 2002-2006 Acura Integra Hatch Strut Replacement: paso 4, imagen 2 de 2
    • Remove the lower ball mount.
    • Turn the lower ball mount counterclockwise with a 12mm wrench.
  5. 2002-2006 Acura Integra Hatch Strut Replacement: paso 5, imagen 1 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 5, imagen 2 de 3 2002-2006 Acura Integra Hatch Strut Replacement: paso 5, imagen 3 de 3
    • Place a washer on the new upper ball mount.
    • Turn it clockwise to hand tighten the new upper ball mount.
    • Turn it clockwise with the crescent wrench to finish tightening.
  6. 2002-2006 Acura Integra Hatch Strut Replacement: paso 6, imagen 1 de 2 2002-2006 Acura Integra Hatch Strut Replacement: paso 6, imagen 2 de 2
    • Place a washer on the new lower ball mount.
    • Turn it clockwise to hand tighten the new lower ball mount.
    • Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
  7. 2002-2006 Acura Integra Hatch Strut Replacement: paso 7, imagen 1 de 2 2002-2006 Acura Integra Hatch Strut Replacement: paso 7, imagen 2 de 2
    • Place a lower hatch strut socket over the new lower ball mount.
    • Push it firmly onto the new lower ball mount. It will pop on easily.
  8. 2002-2006 Acura Integra Hatch Strut Replacement: paso 8, imagen 1 de 1
    • Place the upper hatch strut socket over the new upper ball mount.
    • Press it firmly onto the new upper ball mount. It will pop on easily.
Conclusión
Michael Hagar
Miembro Desde 10/07/19
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 688
