Introducción
When the battery in your 2001 Volkswagen Passat key fob no longer works, you will not be able to enter the locked car or trunk without using your key for entry. Use this guide to replace the battery in your key fob.
Partes
No se especificaron partes.
Press the release button on the key fob so that key is extended.
Locate the small indentation in the middle of the key fob.
5 personas más completaron esta guía.
2 comentarios
My neighbor's key broke off the end for her 2001 Passat. She knowing that I am quite handy, asked me if I would try repairing it. I fixed it twice before. Now, instead of simply applying JB Weld again to the minimal surfaces and temporarily fixing it again, I want to disassemble it and repair the key with silver solder. I need a diagram of taking it apart so I can reassemble it so it functions like a new fold-up key fob should. This is such a handy thing, I just need to a diagram. C'mon, VW? Be a sport?
