Saltar al contenido principal
2001-2005 Honda Civic Tail Light Replacement
Qué necesitas
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: paso 1, imagen 1 de 1
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: paso 2, imagen 1 de 1
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: paso 3, imagen 1 de 1
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: paso 4, imagen 1 de 1
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
Conclusión
To re-install a tail light, follow these steps in reverse.
2 personas más completaron esta guía.
Tyler Smith
Miembro Desde 10/23/13
846 Reputación
3 Guías creadas
Equipo
Un comentario
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 41
Todo El Tiempo: 8,430
