Saltar al contenido principal
2001-2005 Honda Civic Oil level Check and oil change
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. 2001-2005 Honda Civic Oil level Check and  oil change, 2001-2005 Honda Civic Oil level Check and  oil change: paso 1, imagen 1 de 1
    • Warning: Improper maintenance or use of unapproved materials may lead to major issues with your automobile
    • Step 1: Turn off your vehicle and wait a few minutes.
    • Starting this process with a running or hot car may cause damage to both the engine as well as the person performing the maintenance
  2. 2001-2005 Honda Civic Oil level Check and  oil change: paso 2, imagen 1 de 1
    • Remove the dipstick from its' holder and wipe it down with a clean cloth
    • After cleaning, replace the dipstick and remove it again
  3. 2001-2005 Honda Civic Oil level Check and  oil change: paso 3, imagen 1 de 1
    • If an oil change is not necessary, the oil will be a dark brown, and the level will be in between the two notches on the dipstick.
    • If the level is too high or low, it's time to add/change the oil
  4. 2001-2005 Honda Civic Oil level Check and  oil change: paso 4, imagen 1 de 1
    • Step 1: After running the car to normal operating temperature, turn off the vehicle and remove the black and purple oil fill cap.
    • Underneath the car, use your ratchet socket wrench to remove the oil drain bolt and washer.
    • Remove the oil filter from the tank and allow all of the oil to drain out.
  5. 2001-2005 Honda Civic Oil level Check and  oil change: paso 5, imagen 1 de 1
    • After all of the oil is drained out, replace all parts in reverse order that they were removed.
    • If the oil filter appears old or damaged, it is wise to replace it. Oil filters can be found at any auto parts store
    • Add 5W-20 Motor oil to the level indicated in your owners manual.
Conclusión
7 personas más completaron esta guía.
Tyler Smith
Miembro Desde 10/23/13
846 Reputación
3 Guías creadas
Equipo
2 comentarios
Where is the oil filter located? An important step was left out!!
Gil - Contestar
This guide has been retired and is no longer being updated. Please use the latest version of the 2001-2005 Civic oil change guide. Thanks!
Jeff Suovanen -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 4,395
