Saltar al contenido principal
2001-2005 Honda Civic Front Brake Pads and Rotor Replacement
Qué necesitas
Instrucciones de Vídeo
Conclusión
2 personas más completaron esta guía.
eCuration
Miembro Desde 05/19/17
376,693 Reputación
234 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,734 Guías creadas
2 comentarios
kudos for making the video. The main reason I like to “see” these jobs done is to know what to expect before I start a job. I haven’t seen an impact screw driver in forty years though!
Stephan Eichinger - Contestar
Change your video… 80K views for a non-pro... The slots in the surface are for Gas Evacuation; ie: from the resin in the pads. The slotted rotors fins are for cooling. If you are in there for rotors: Why Not pull the pads ( and de-glaze with some emery-paper on a true surface). Pull and lube the sliders and re-anti-seize the pad-backs and clips ? ps: Compress the pistons makes sure they slide. This is basic brake-care and you should get at least two pads sets to one rotor replacement. ps: Don’t learn from me- i ain’t no pro. pps: Me too with a rotor-parts mix-up even after watching the 'Pro's' at SouthmainAuto and Ericthecarguy.
paul rattenbury - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 58
Todo El Tiempo: 13,083
