Saltar al contenido principal
2001-2006 Mini Cooper Radio Replacement
Qué necesitas
  1. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: paso 1, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: paso 1, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: paso 1, imagen 3 de 3
    • Grab the knee bolster panel under the steering column with both hands.
    • Pull it down and out.
    • Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
  2. 2001-2006 Mini Cooper Radio Replacement: paso 2, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement: paso 2, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement: paso 2, imagen 3 de 3
    • Open the glovebox.
    • Using a Torx screwdriver with a T20 tip, remove the two M5 x 2.5 x 30 screws in the right hand side pillar.
    • Minis in America will usually have a cup holder attached with these 2 screws on the right. It will come off when the 2 screws are removed and can be set to the side.
  3. 2001-2006 Mini Cooper Radio Replacement: paso 3, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement: paso 3, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement: paso 3, imagen 3 de 3
    • With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
    • Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
    • Pull each side of the middle dash panel until it pops out, like the previous ones.
  4. 2001-2006 Mini Cooper Radio Replacement: paso 4, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement: paso 4, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement: paso 4, imagen 3 de 3
    • Grab the left hand side pillar, then pull it out and to the left.
    • Grab the right hand side pillar, then pull it out and to the right.
    • The four screws holding the radio in should now be exposed.
  5. 2001-2006 Mini Cooper Radio Replacement: paso 5, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement: paso 5, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement: paso 5, imagen 3 de 3
    • Using a screwdriver with a T20 bit, take out the four M3 x 2 x 20 screws holding the radio in place.
  6. 2001-2006 Mini Cooper Radio Replacement: paso 6, imagen 1 de 2 2001-2006 Mini Cooper Radio Replacement: paso 6, imagen 2 de 2
    • Grab the radio and gently pull it out of the dash.
  7. 2001-2006 Mini Cooper Radio Replacement: paso 7, imagen 1 de 3 2001-2006 Mini Cooper Radio Replacement: paso 7, imagen 2 de 3 2001-2006 Mini Cooper Radio Replacement: paso 7, imagen 3 de 3
    • Pinch the antenna connector and pull it straight out.
  8. 2001-2006 Mini Cooper Radio Replacement: paso 8, imagen 1 de 2 2001-2006 Mini Cooper Radio Replacement: paso 8, imagen 2 de 2
    • For the main connector, pinch the lever arm with the piece of plastic next to it.
    • Lift up on the arm and pull the connector out.
    • The radio can now be removed from the car.
Conclusión
5 personas más completaron esta guía.
Un comentario
I bought everything to install a aftermarket radio in my 2005. Mini s. Everything lights up. Stations tune in but no sound
Roy Ober - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 71
Ultimos 30 días: 266
Todo El Tiempo: 11,484
